Twin air + jet kit ---Z250
Old 12-22-2003, 03:07 PM
CHEWBACCA's Avatar
Default Twin air + jet kit ---Z250
if i get a twin air air filter, will i need to get a jet kit? And how do you use jet kits? whats better, Twin Air or Uni? and if i get both, will i notice a difference?
Old 12-22-2003, 03:33 PM
LT250RSuperstar's Avatar
Sorry CHEWBACCA I can't answer this for ya.....just figured I could get some attention for ya by replying.
later
Superstar
Old 12-22-2003, 03:56 PM
GTFZ250's Avatar
No u wont i got one and it is Twin air, runs fine no jet kit and i pull my cousins yellow 250 after i stop spinning of the line and i get to the top end now. dont get a uni less power increase. but i dont run without the air box lid very often cause of my places i ride but it souldnt be a problem if u are going to. O and a quick tip wipe down the area aroung the inside of the airbox when u replace the filter and clean out the airbox lid snorkel if u use it.
Old 12-22-2003, 04:00 PM
GTFZ250's Avatar
o and i see that u ordered a clutch kit when u get it on could u tell me about how it is because i am really considering getting one thanks
Old 12-22-2003, 04:04 PM
04SuzukiZ250's Avatar
You will NOT need to rejet with the filter. I have a twin air one and i didn't rejet and it runs a little bit beter.
Old 12-22-2003, 04:18 PM
CHEWBACCA's Avatar
oh thanks and yeah GTFZ250 ill tell you when i get it. It should have came like a week ago but i guess that since UPS is so busy it might take a while
Old 12-22-2003, 05:00 PM
Dan308's Avatar
CHEWBACCA, all you're doing is changing the air filter. It's not going to change anything. Foam is foam, it doesn't matter who makes it.
Dan308
Old 12-22-2003, 05:06 PM
CHEWBACCA's Avatar
im just saying that when i need to get a new air filter i just want to know what i should get and if they would make a difference
Old 12-22-2003, 05:39 PM
Dan308's Avatar
Any foam filter will work. There are no benefits from one to the other. Don't listen to hype. I can give you a link that will help you understand jetting if you'd like.
Dan308
Old 12-22-2003, 05:55 PM
CHEWBACCA's Avatar
ok
Quick Reply: Twin air + jet kit ---Z250
