ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Suzuki (https://atvconnection.com/forums/suzuki/)
-   -   difference between 85-87 lt250r's? (https://atvconnection.com/forums/suzuki/132467-difference-between-85-87-lt250rs.html)
jstaguy24 Jan 9, 2004 12:49 AM
I have a 1985 Suzuki Lt250r frame. It doesnt have the original motor in it but I want to get a six pack rack and outerwears shock covers for it but they only show for 87 and up lt250s . does anyone now the difference and if the six pack rack and shockwears will fit the 85.
thanks
rockrider Jan 9, 2004 01:55 AM
Yeah, the six pack rack should fit since the frames arn't that different. I believe the '87 got revised front end geometry, longer travel front & rear and the powervalve engine. I bet the shockwares will work but honestly, I think they are a waste of money since the shock shaft is is already protected by a plastic sleeve and the shock wares tend to hold in mud and crud unless they are pulled off when washing the quad.
sam250 Jan 9, 2004 01:00 PM
The 85-86's have 12" front shocks and the 87-up have 15" fronts, so the shockwears won't fit. I got a 6-pack rack from PRM that fits well.
Does your quad vibrate alot? They say that dirtbike engines in quad frames tend to break motor mounts and vibrate alot 'cause they're not counterbalanced. Have you found this to be true?
jstaguy24 Jan 10, 2004 12:29 AM
It does vibrate but not that bad. You will want to locktite your nuts and things on it so they dont come loose but I only notice the vibration when im at an idol When im riding i dont notice it all.
© 2026 MH Sub I, LLC dba Internet Brands
