ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Suzuki (https://atvconnection.com/forums/suzuki/)
-   -   shifting gears when engine's off... (https://atvconnection.com/forums/suzuki/135653-shifting-gears-when-engines-off.html)
danbleh230 Jan 29, 2004 07:12 PM
i tried to shift gears on my quadsport lt230s while my engine wasnt running, and i could only shift from 1-Neutral-2.
is it normal that i cannot shift thru 3 and + while the engine isnt running?
LT250Rodney Jan 29, 2004 07:19 PM
Sometimes yes. Roll the engine over slightly, or roll the machine back and forth a bit and then see if it still wont do it. You may have the two gears lined up dog to dog so they wont engage. It just needs to turn slightly and it'll drop in. If not then you do have a problem.
danbleh230 Jan 29, 2004 11:05 PM
i'm gonna put my new magneto cover, fill it with oil and try it tomorrow. I'll keep you updated.
thanks
danbleh230 Jan 30, 2004 06:24 PM
all tried all day long
at one time i've been able to shift from Neutral to 5th
it will downshift to neutral, but from there i was only able to shift to 2nd and 3rd. it wont downshift to 1st though.
what problem can it be?
LT250Rodney Jan 31, 2004 02:00 AM
If it shifts fine when its running then what are you worrying about? Just because it wont shift gears while its sitting still does not mean somethings wrong. Its normal. The transmission has to be rotating for it to engage a gear, it is not syncronized in any way so there is no blocker rings or any syncros to help it slide into gear while its not rotating. You sometimes cant even get a car into gear when its sitting just for that reason. Stop worrying about it and go ride it!
Hozed Jan 31, 2004 09:20 AM
i second that motion.. its not a big deal.. just have fun riding..
hondabuster Jan 31, 2004 09:31 PM
motorcycles and atvs use a type of transmission called, constant mesh. The spinning of the gears assist the shifting, if the gears arent spinning, then theres no assist. If you rock the machine , forward and back, and at the same time try shifting, youll see it will shift just fine. Its a normal characteristic of the tranny.
gearbox
you can read more here.
danbleh230 Jan 31, 2004 09:33 PM
interesting link hondabuster, thanks!
mudrover Jan 31, 2004 10:52 PM
on my lt230s its the same way the guy at the shop said it was normal
© 2026 MH Sub I, LLC dba Internet Brands
