HELP...for the life of me I can't find the output terminal that is supposed to be on the right hand side of the gas tank. I found the one in the rear next to the storage box.
But I can't locate the other. Today I took the plastic cover off, the one under the gas tank, because I figured the output term was well out of sight. Removing this plastic piece didn't help, I still can't locate it. The owners manual clearly shows where it is and I clearly can't find the damn thing. Could it be that the dealer used the output terminal in the front for the winch they installed on my quad??? Thanks |
c4drm... Its there, it is on the right side, but not directly below the tank, more towards the fender a little bit. Its tied up to an existing wiring harness, so it could be hidden in the other wires. You'll find it, just keep looking.
[This message has been edited by r34 (edited 01-22-2000).] [This message has been edited by r34 (edited 01-22-2000).] |
How do these terminals work? I was under the impression that they were made to hook a cigarrette lighter attachment in them like the ones that are in vehicles. It almost looks like it is that type of terminal but with a plastic plug to keep water and mud out since it has an extra clip infront of the plug to keep the plug-in from flopping around. If it isn't this type then I guess you have to splice the wires into the plug. Thanks.
------------------ Jeremiah Lucas 1989 Yamaha Banshee & 99 Suzuki LT-F500F Quadrunner |
r34...I'll look again, tx.
Venomous, I've got no idea what these output terminals are used for or what one could plug into them? I was expecting the samething you were (i.e. cigarrette lighter type outlet r34 or anyone else, any ideas??? |
I bought an extension from Suzuki that plugs into the factory terminal and has loose wires on the opposite end for putting whatever kind of plug on it, for example a cig lighter receptacle. It's 3 or 4 feet long and was $20. This was for the KQ but may be the same for the 500s.
Z |
correction; the extension cord I mentioned is actually 6-1/2 feet long.
Z |
Z...thanks for the tip, I'll have to pick one of those up.
