lt250r powerband
Hi i was wondering if any one could help me out on why my powerband isnt coming in and hitting hard.I have a 91 lt250r thanks
lt250r powerband
your carb needs rejetted or could lose on a worn crank...
lt250r powerband
lol
lt250r powerband
Make sure that the powervalve adjuster hasnt come loose. I believe if it slacks off your power curve will be pretty flat. Otherwise get out the compression tester and do the ususal steps...
lt250r powerband
hey thanks for all of the advice i chcecked my powrvavle and it isnt loose and i was wondering what i should jet it at.....it has a paul turner pipe and running ams oil in it
lt250r powerband
Just look at your plug. It should be a nice tan brown color on the insulator. Black is rich and white is lean, more or less. Go from there.
lt250r powerband
Mine has no real hard hit anywhere in the band and look at all my mods. I never rode another Lt so I have nothing to compare it to mine does have gobs of low end though. I think the powervalve smooths out the power so much that there is no real jump in power all at once. I spoke to a guy who had a powervalve GAS GAS wild 300 and he said that although the GG would smoke a trx 250r it doesn't have the hard top end hit because the powervalve smooths out the power. If you figure it out let me know
