ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Suzuki (https://atvconnection.com/forums/suzuki/)
-   -   Can't remove impeller on LT250R (https://atvconnection.com/forums/suzuki/174484-cant-remove-impeller-lt250r.html)
rockrider Sep 30, 2004 03:12 AM
I've removed the case cover from the motor. Removed the impeller bolt but the impller won't come off the shaft. I've tried to tap the shaft through with a dead blow hammer but no luck. I haven't tried hitting it super hard for fear of damaging something. Am I doing this correctly? I need to remove the impeller to replace a leaky water pump seal.
projectquadracer Oct 5, 2004 02:37 PM
use a couple of screwdrivers and pry the impeller off and the bearings for the water pump are just pressed in on the back side of the case nothing too awful wd-40 will help out alot. ~Josh
© 2026 MH Sub I, LLC dba Internet Brands
