700kq drainplug location?
The drain plug is under the right foot panel under the skid plate just inside the frame rail not far from the right foot peg. The skid plate has to be removed. I believe it only has 6 or 8 bolts to take the skid plate off, it's pretty easy to remove. You may want to cut a small hole in the skid plate near the plug for easy access in the future.
11/26/2004
Hello All!
The KQ Belt case vent is located up under the rear fender plastic... It is pretty high but in my case I was in really deep water any deeper and I would have had water in the air intake.
Access to the plug is pretty strange, I think the reason Suzuki covered it was because it is just a simple rubber pull plug and they may have been concerned with it being knock out on harse terrian...
In the meantime I just returned from a hunting trip in north central WV and had the KQ in some really sloppy deep water and mud that was at times over the wheels, not as deep as the lake I was riding in, and I didn't encounter any issues with the case flooding or the belt slipping. So it would appear that my experiance was caused by extremely deep water. The access hole I put in the plate has worked very well at one point I check the case deep in the woods of Coopers Rock state forest and it made it simple to check and there was no water in the case.
Later,
Hibrass
Hello All!
Later,
Hibrass
10-10-2015 10:20 AM
