ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Suzuki (https://atvconnection.com/forums/suzuki/)
-   -   HELP! I can't get my Zilla to start. (https://atvconnection.com/forums/suzuki/197759-help-i-cant-get-my-zilla-start.html)
emeraldisleatv Mar 30, 2005 03:59 PM
After doing a top-end rebuild and restoring my zilla I can't get it to start. I had spark trouble but got it sorted. Now I have a spark and it is gettin petrol. Could it be a carb prob? I've tried kickin and pullin it but no go. Its turnin over fine but just won't start!
donzilla Mar 30, 2005 05:35 PM
make sure the kill switch wires are in good shape and connected . same with the key switch .
next choke on , switch off . kick it three times . then turn switch on no throttle get it to top of stroke then kick . if after a few times if i doesnt start turn off choke and drain fuel from carb ( take off bowl bolt on bottom of carb ). if after a few seconds gas is still pouring out , i would say float is stuck . might need to clean carb .
emeraldisleatv Mar 31, 2005 02:36 PM
Thanks donzilla. I didn't get time to open the bowl yet, but I will. When you think about it it must be carb probs as there is a spark, air comein to the carb so the last prob is fuel/intake.
wildcard Apr 1, 2005 12:54 AM
check your reeds this is very important on a two stroke make sure the are sitting down flat so they seal half decent if they dont you can flip them over
emmerth Apr 1, 2005 09:37 AM
Have you checked the plug to see if it wet with fuel???
emeraldisleatv Apr 3, 2005 01:15 PM
Sorry I haven't been online lately. But here is the situation at the moment, I opened up the carb and the float is not stuck, I blew out the carb with air but still no luck then I got a new plug and still nothing. The one thing I made sure of putting back the reeds is that they lie flat and the plug is wet coming out. I've tried putting some petrol down the plug hole. Next thing I might try is heating the plug. Any more ideas with what could be wrong. Also while pulling the quad there is a mist of petrol from the exhaust. Also there is good compresion. This thing is gettin on my nerves at the moment.
86LT250RFatty Apr 3, 2005 04:05 PM
check to make sure the timing is correct, and that you allighned the stator in the right position, lining up the two marks.
emeraldisleatv Apr 3, 2005 04:07 PM
Hey guys. Just took off my reeds and there sealing properly, but i found some gasket maker which ozzed out i took it out but there could be more, could this be the prob. Also I got someone to check out the carb and everything is ok. Doesn't makes sense I've got spark and petrol! WTF is goin on!!!!!!!!!!!!!!!!!!!!
dissimilar Apr 3, 2005 05:40 PM
You didn't respond to 86LT250RFatty's question. Are you positive that the flywheel and stator are installed correctly?
Evilution Apr 3, 2005 11:53 PM
Did you thought about the gas... is it old ?
Did you perform a leak test ?
© 2026 MH Sub I, LLC dba Internet Brands
