1993 Suzuki Quadrunner won't go into neutral
I'm having some problems with my Quad. It's a 1993 Quadrunner 4wd, and for some reason it won't go into neutral. It will go into reverse just fine, but by not going into neutral, the electric start won't work. Does anyone have any suggestions?
If its a manual tranny, then check the Idle, because if its too high then neutral will be a pain in the a$$ and it would still go into reverse because reverse is a gear
Nah, it an automatic. The green "neutral" light won't light up, but like I said, the electric start won't work either, so I know it's not just that the light is burnt out.
wait its automatic but it wont go into neutral, meaning that it wont start at all? Do you have to put it into neutral with a shifter or a button?
| All times are GMT -5. The time now is 09:53 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
