z400 mods
Old Oct 28, 2005 | 08:57 PM
RippnZ400's Avatar
Default z400 mods
Ok, as my sig says, I'm looking to buy a Yoshimura RS-3 Comp Full System with the Carbon Fiber canister, a power pack or pro power pack, which includes kn filter, jets, outerwear, and pro has a billet base plate for filter, and then a rev box. I remember reading about people talking about the best rev box to upgrade to and I think final decision was a ignition that had a programmable and non-programmable and that for non-programmable version it upgraded rev limit and advances timing a bit for around 200 bucks, what is this ignition? Also, is the power pack worth getting? or should i buy like outerwear, jets and kn filter? Thanx
Old Oct 28, 2005 | 10:38 PM
witti's Avatar
Default z400 mods
Dyna ignition, advantagecyclelc.com has the best price that I have found.
What's the price on the power pack? I paid ~$90 for my nossmachine filter adapter and K&N with outerware. Jets are ~$5 each, and I think a needle is $15-$20 (Alba), or you could use the stock needle.
Your pipe should come with a couple jets, should get you close.
My dynojet kit wasnt worth buying. It didnt have a big enough main jet, and I developed a burble with the needle. I ended up buying another jet and ran the stock needle.
Old Oct 28, 2005 | 11:32 PM
RippnZ400's Avatar
Default z400 mods
power pack without billet base plate is around 110 for Z400, and 140 with Z, and has dyno jet kit, kn filter, outerwear, and base plate in the pro power pack (pro kit just has base plate)., thanx that was ignition i was looking for.
Old Oct 28, 2005 | 11:34 PM
RippnZ400's Avatar
Default z400 mods
so how much was ur ignition? and finally how much and from where did u get reverse over ride?
Old Oct 29, 2005 | 09:33 PM
witti's Avatar
Default z400 mods
I paid $350 for my Dyna. It was before the cheap version came out.
Do a search on "reverse" you will find the instructions under a rescent post.
Old Feb 9, 2006 | 08:54 PM
24houradrenaline's Avatar
Default z400 mods
The dyna fs programable ignition has a reverse overide built into it.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
