05 ltz400 using excessive coolant
Old Oct 10, 2006 | 09:21 PM
Henley22's Avatar
Default 05 ltz400 using excessive coolant
I went riding at coal creek this past weekend after i had my z serviced, they put the clutch cover recall on. It now seems i went from low to almost no coolant in about 5 hours riding time anyone know why this is happening? the coolant light never came on and it is operationsl so i dont think i overheated anyone help me???
Old Oct 10, 2006 | 10:15 PM
BlackKawi400's Avatar
It's possible that the coolant never actually circulated into the motor until you rode it enough to warm it up. (the motor has to heat up to open the thermostat)
I would add more coolant to top it off and get it back up to operating temperature and see if you lose any more. For added security you could change the oil again and see if any coolant has seeped into the oil.
Old Oct 10, 2006 | 11:13 PM
mucky's Avatar
check your oil. if it looks like chocolate milk take it back , but like black kawi said they might not had enough coolant in it to start with.
I had that problem after I did my 470 and it was the head gasket wasnt sealing right
I also ran a can of block sealer in mine for about 15 mins then drained it and let it set for 24 hrs to dry then filled it with new coolant and havent had a problem since
Old Oct 11, 2006 | 10:11 AM
RTOYZ's Avatar
both of our did the same thing after the recall. We added coolant to the reservoir and have not had the problem since.
Old Oct 11, 2006 | 02:46 PM
kawiking's Avatar
probably didnt have enough n there. if you rode hard all day ,id go ahead and do a oil change ,just to make sure.
1ArmBandit
55
Oct 14, 2015 09:03 PM
2many2ride
Sep 27, 2015 04:35 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
