z400 grease
Hey, my friend got a z400 used, Where are the grease fittings???
z400 grease
in the service book there is 7 points to check and grease/lube 1. brake lever holder 2. throttle lever 3. steering stem holder 4.brake pedal and rod link 5. brake cam 6. drive shaft joint spline 7. rear suspension link shaft. lube every 3 months
there is only 1 grease fitting, its on the rear shock link |
