Tech enging question for the z-400 expert!
So, I'm trying to sort out a knocking noise in the engine of a Z-400.
Q 1. about the counter balancer, should there be pins inside all the springs or just 2 of them. I only found 2 springs that had a pin in the center.
if it's only "2" where do they go in relation to the locating dot.
Q 2. about the clutch basket, on the back side of the clutch basket are springs, should all of them be tight (pre-loaded) because I found some that were loose with almost 1/4 of play (back and forth movement)
Neither seemed right???
Thanks for any info/help
speedbuff
13
11-11-2020 10:16 AM
Elkaholic
09-06-2015 02:44 PM
