2005 Eiger 400 won't shift gear
Old Mar 25, 2008 | 11:28 AM
snowdrifter's Avatar
Default 2005 Eiger 400 won't shift gear
Unit appears to be stuck in 2nd gear. any ideas as to the problem
Old Mar 25, 2008 | 10:33 PM
rolsmojave3's Avatar
Is all of the shifter linkage still connected? Maybe try adjusting the linkage. Does it not shift with the bike running, while moving, we need a tad more info.
Old Jun 29, 2020 | 01:08 PM
lstuart's Avatar
Default Suzuki Eiger 400 4x4 stuck in 2nd gear
I am having the same issue with my 2004 Suzuki Eiger 4x4. Won't shift out of second gear with it running or not, moving or not.
Old Jun 30, 2020 | 03:12 AM
Check the Hi/Lo/reverse lever hasn't got fouled up, and the link from pedal to gearbox, but I would guess at a selector mechanism problem inside the gearboxes, very complex, and the 5 speed is in the clutch side, and the hi/lo reverse in the alternator side, but both are linked.
Old Jun 30, 2020 | 09:56 AM
lstuart's Avatar
thanks I’ll check it out!
Dianna
Jul 15, 2019 01:18 AM
SusieS
Sep 17, 2016 02:02 AM
jdj1215
Aug 25, 2011 03:42 PM
13speed
Apr 1, 2008 10:18 PM
