Suzuki Eiger 400 - 4WD switch
I am looking to buy a used Suzuki Eiger 400. After a test ride and quick visual inspection everything looks good but the 4WD switch just flops up and down. I don't know much about the machine or the switch function itself. Is it likely a broken cable, loose cable or something broke within the switch itself? If the whole thing needs replaced, what is the PITA factor (pain in the a**) to replace it and what would be the rough cost?
Thanks ! Any help would be appreciated. |
You can only buy the entire lever assembly, about $80. The cable could be broken but more likely the small plastic cam inside the lever can also break. It's easy to replace, hardest thing is shelling out the $80 for parts.
Jaybee |
The switch does move easy on it's own. Your sure it it not working?
If the cable or the lever internals breaks, the bike will default into 4wd.
Jaybee |
All,
Thanks for the information. If it is still for sale, I will likely make an offer on it this weekend... and yes, the switch is broken - flops up and down on every bump. I could tell it was staying in 4wd during cornering, something I will "have" to get used to since I mostly ride sport atvs. |
Someone on ebay sells an aluminum inner cable holder that replaces the factory plastic one in the 4wd switch.
