ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Suzuki (https://atvconnection.com/forums/suzuki/)
-   -   Can't remove the brakes! (https://atvconnection.com/forums/suzuki/326983-cant-remove-brakes.html)
softap May 10, 2010 03:56 PM
For some reason, the front right brake drum will NOT come off of my 1988 Quadrunner!!
I have tried prying it, smaking it with the wheel on ... and off!
I have soaked it in penetrating oil .... nothing .... I need to remove this so I can put on new brakes!!!
Thanks ... oh yeah, it's on the front !
NewportHillClimber May 10, 2010 09:04 PM
you may have to take the cable end loose from the pivot on the back of the wheel and use a pair of pliers and make sure the pivot is totally loose. then it should come off
softap May 10, 2010 09:10 PM
I don't have a cable on the backside. They are hydraulic brake drums.
Sisco1957 May 10, 2010 09:20 PM
The pistons in the wheel cylinder are stuck. Suzuki is bad about doing that. I have had better luck getting the drum off by removing the bleeder screw on the cylinder and prying and pecking ( not to hard) on the drum. Clean the cylinder, pistons and reassemble. I use a piece of 1/2" pcvc pipe with 2 slits cut it it and wrap a piece of emery cloth in the slits for a hone. Make sure the pistons move freely in the cylinder.
softap May 11, 2010 12:19 PM
got her off!
NewportHillClimber May 12, 2010 05:57 AM
Nice
© 2026 MH Sub I, LLC dba Internet Brands
