2005 kingquad 700oil cooler
i would like to add a oil cooler to my 2005 kingquad.its a 700. has anyone tried this.i ride a lot a figure it could only help.1 thought is to make a new filter hook up. build a plat to extend the filter out and run lines from there.two is find a port of some have not looked in to it a whole lot.but would this be a good thing to do? any ideas or such would be cool to hear thanks
The ATV is CVT so the oil has nothing to do with the gears like a manual shift and the motor is liquid cooled, I do not see any gain in doing the work.
Just use a good grade full synthetic motor oil it holds up to high heat better than conventional oil, and that all it will ever need. |
