2002 vinson front drive shaft removal
I'm tryin to pull the front drive shaft out of the front diff on a 2002 suzuki vinson to replace the input seal.. it will not come out is there anything i need to know .. a clip or just pull harder i dont get it ..
On my vinson there are are three bolts that hold the driveshaft in place
you have to remove the diff and then split the diff housing body. Inside by the slide for 2wd and4wd you will see a circlip on the input shaft , remove this then tap gently on the collar it was up against and the whole input shaft will come out. Dont forget on refitting to put the circlip on the end of the shaft before fitting back in tight
