lt185 starts, runs, heats up, dies.
Old Dec 12, 2011 | 09:23 PM
har_v's Avatar
Default lt185 starts, runs, heats up, dies.
I have a suzuki lt185 that starts on the first or second pull, idles great.
Runs for 10-15 min then after begins to idle poorly. Eventually dies.
Won't start for about 15 min till it cools.
Pretty sure this is an electrical problem. Something breaking down with heat. Coil? Where would you look first?
Anyone have this problem? Thanks.
Old Dec 23, 2011 | 08:46 PM
har_v's Avatar
Bump,bump,bump...
Checked ohms on all coils (ignition, primary, pickup) all within spec (cold).
Replaced CDI from running unit.
Same problem. Need some help folks!
Old Dec 23, 2011 | 10:30 PM
richardw's Avatar
Testing them cold isn't telling you anything, it runs when it's cold so there is no problem until it heats up. My bet is on the ignition coil. Swap coils with the running bike you took the cdi off of.
Old Dec 29, 2011 | 06:38 PM
har_v's Avatar
Thanks for your response...you are right. Checked them again and all were within spec (hot or cold).
I have checked more since my first post....but wheeler still has the same problem.
Will start and idle. As it warms up (within 15 mins of idling or driving) it gradually idles rougher. I can keep it running by gradually turning in the idle adjustment from two out (spec) (opening for more air), until it goes all the way in.
When engine stalls, plug is black with carbon, suggesting running rich.
Rocker clearance on valves was within spec at tdc on compression stroke.
Timing is not off (pulled cover and checked). Gas system is clean.
Valves seem to be seating and with compression over 150psi....not great but ok I would think.
Have been though the carb....set float replaced needle and seat.
Currently cleaning it again, because I am out of ideas....
Really would like to figure this thing out.....
Old Dec 29, 2011 | 06:39 PM
har_v's Avatar
btw....also replaced ignition coil...no luck still runs the same.
MikeyBoyesq
Nov 27, 2020 02:44 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
1000gade
May 27, 2015 12:37 PM
