Clutch adjustment
Does anyone know what the clutch adjustment procedure is for a 2001 suzuki quadrunner 500 (semi auto)? Thanks.
I'm presuming that your talking about a clutch adjustment not the adjustment that positions the shift lever.
I looked at the parts fiche and don't see anything that would indicate that there is a adjustment. I know that my LT230E don't have one and they are basically the same clutch parts wise. I certainly could be wrong. |
On my 2000 king quad there is a little adjustment in the clutch pack. Mine is a semi-auto (no clutch lever but you have to shift with a pedal) open the clutch pack cover, the adjuster should be very visible ( center or pack). Also check your plates and make sure they are not warn too far down, replacing them might be all the adjustment you need.
