1997 Trailblazer flooding
My 1997 Trailblazer 250 was starting on the 2nd or 3rd pull but now floods out so bad the exhaust fills up with fuel/oil. I pulled the carb and with the carb disconnected and sparkplug installed it still puts a fuel/oil mix out the exhaust. What is going on here?
I'd do a compression check first. Should be at least 120 psi or so.If lower,then could be time for a freshen up on the engine. If compression is ok, it could be as simple as needing a new carb kit. Next time on questions try posting in the Polaris section as the Suzuki guys might get a little hostile toward us... :)
I've cleaned the carb and will try and get a compression tester. Is it possible for 8 ounces of fuel to be in the motor? I got around that amount out of the motor without the carb connected
The float malfuntioned and filled the motor with fuel.
I'd say more but i'm getting hostile...LMAO :D |
Originally Posted by LT80
(Post 3200451)
