Lt160 transmission issue.
Working on a 1989 Suzuki Lt160 quadrunner. I replaced everything in the transmission and it was in neutral when I put the engine back together. Mounted engine in frame and now motor is stuck in reverse. Any Ideas?
Thanks |
The only thing I can think of is the reverse shift shaft is in the wrong position inside the transmission. Did you try to turn the counter shaft sprocket before putting the motor back into the frame.
I don't know the LT160 but if it has a cable/rod operated linkage like most Suzukis, have you got the external lever on the side of the box on the right spline?
