04 Eiger lt A 400 4x4 won't idle
I have a 2004 suzuki eiger 4x4 automatic. It's hard to start , once started it will idle for 30 seconds to a minute then shut off. When I'm able to get it in gear it will run fine as long as I'm riding, but will die when I stop and is really hard to restart. I have removed and cleaned the tank , replace the petcock with a non vacuum type, and clean and rebuilt the carb. Im scratching my head.
Is it easier to start cold? Do you need choke? Take a look at the spark plug colour, if it is black and sooty your choke is probably stuck slightly open, if white, it may be running weak due to some dirt still being in the carb.
Originally Posted by Amtrack
(Post 3337641)
Originally Posted by merryman
(Post 3337701)
Originally Posted by Youngblood250
(Post 3337703)
Sounds like a classic case of your pilot jet is clogging up after startup. Did you blow compressed air through every thing before putting it back together?
(Post 3337756)
I did blow through everything, and replaced the Jets. I'm starting to wonder if maybe it's loosing fire some how. I started it this morning, took several minutes of cranking. I backed it off the trailer, stopped put in H drove across the yard put in neutral idled for about a minute and it shut off. Runs fine under load , just hard to start and won't idle.
This problem reminds me of a problem I had with a lawn mower of mine. Would run for a while then backfire and die. Let it set for a while then it would fire right back up. I rebuilt the carb 2 or 3 times and still wasn't fixed. Turned out it was the coil breaking down after it heated up. I replaced the coil and updated to electronic ignition and never had another problem until a valve seat came loose. Maybe this is the same problem you have? |
(Post 3337787)
If you hadn't already replaced the petcock I would think it's that. Had a very similar problem with my Ozark one time. Would idle but wouldn't accelerate then wouldn't idle but would accelerate. Turned out to be the petcock diaphragm bleeding gas post carb throat.
(Post 3337943)
Thanks, I'll try that next. I will update.
I know Arctic Cat uses the same motor, I would also look at the boot between the carb and the air box. Mine was cracked, making it run slightly lean. My mechanic said he had to rebuild one on a 454 Bearcat that actually sucked muddy water thru it and roached the motor. My 2001 AC 500 had the same cracking.
| All times are GMT -5. The time now is 11:36 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
