LT80 - Problems starting, and then stalling.
#101
But Frank, I had a extra..and you didn't notice..right?
Motc777: I utilize a simple on/off valve inline as close to the carb as possible. Then you can shut the fuel off and run the machine till the carb is dry. That way when you want to ride, you turn the valve on and it fills the bowl and washing the needle (that's my theory anyway).
#102
#103
#104
The quad is running awesome right now. Son got on it today, was a little sluggish at first, but fine otherwise. It is, or was idling pretty high, which I found out from the owners manual is that idling screw and that causes the lurching. I finally got it under control and it's idling nicely. Also, the engine is not dying either. Is it possible that it just needed to run flat out for awhile?
Anyway, we need 4 new tires. I don't have the tools to mount them. What is a fair price for a shop to mount tires?
Also, what are your views on running Seafoam through the engine?
#105
Glad to hear it's running well...sometime the crankcase can get flooded with fuel and cause poor running conditions until it is cleared out...that can take some time...
Tires - that really depends on the shop...some will do it for $10/tire, some a lot more...
Seafoam - I use it on my 4-stroke Vmax (mix with fuel) to help keep the pilot jets clean, but I'm not a fan of running anything through the motor...and if you dump seafoam into the tank, on a 2-stroke, it will run through the motor...so personally - no, I do not use seafoam on anything 2-stroke related...
