Drum won't go back on
1997 Suzuki King Quad 300
After changing the brakes the drum is now too tight to go back on. |
I would open the bleed screws and compress the brakes. Should be able to fit then. And then you'd have to bleed them again. I am not familiar with the 97 King Quad so this may not apply.
Are you sure the shoes are on correctly...they can be a real PITA...otherwise I'd ensure you have the correct shoes...
The drums actually get larger in diameter over time...and yours is no spring chicken... |
| All times are GMT -5. The time now is 03:42 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
