crank bearing question
Does anybody know why there is 2 different part numbers for each crank bearing but both bearings are same dimensions? Can i just order 2 of one part number?
https://cimg8.ibsrv.net/gimg/atvconn...5b527a485e.jpg |
Why gamble, might be a ifference you cant see unless both bearings carry the same number on the bearing itself. Any difference in bearing numbers means there is a difference in the bearings. Cutting corners rarely pays off, usually costs more in the long run.
See if LT80 responds he’ll know the answer to the question. |
They are the exact same bearing. The seals list a dif part # for right and left. They are the same also.
FYI: I use Toyo bearings. Much less expensive than Suzuki bearings! I'll get the bearing #'s for you. |
