2005 Suzuki Eiger 400 service manual/issue
Went to start the bike today and it lit off then died. Wouldn't lite off anymore. Turn off the key and wait a few minutes. Try to start again and will lite off the first time then die. The battery was weak so I had the battery attached to a jump box if that makes any difference. I took the carb off and cleaned it to make sure. Checked spark doing the spark plug against metal trick and it has spark. I sprayed some carb cleaner into the intake and it lit off then wouldn't lite anymore. It has fuel and is clean from what I can tell. Any suggestions? I don't have a service manual but sure would appreciate one if someone could send me an electronic one.
Originally Posted by CatTheFelix
(Post 3418261)
Symptoms are a bit like the "loose magnet syndrome" but I assume you have had the alternator case off as you write "Stator and flywheel look fine". Now the fault is "on" check the exciter coil and trigger coil are both sending AC volts to the CDI when you spin the starter. Check if the CDI is sending high voltage pulses to the HT coil, and if it won't spark with a new plug, try refitting the old one.
How do I check those things exactly? I don’t have a manual and not sure what all the readings/wires to check should be.
do simple things first....unplug all electric al connections, spray the inside with WD40..reconnect....then retest.
(Post 3418805)
Thank you all but I got it going. I replaced the battery and the brushes in the starter and it started right up. I can’t explain how or why but it runs again.
