Can this be welded safely?
You should be able to find a 85-86 swingarm on EBAY for short money real easy. I have a 92 and that year swingarm is not interchangable with any others, so I had three cracks welded by some hack, one rebroke along the top of the swingarm, so I had a real good welder weld the crack and weld a piece of alluminum over the seem, it hasn't broke since.
yes , your swingarm can be welded safely. welds are stronger than the metal around it (if done correctly) just make sure the person you have doing it is a good welder. The tig process is the best process for aluminium
Customer Service #1
May 15, 2020 08:46 AM
greg86hd
Sep 16, 2015 12:32 AM
