The latest quad in my shop is a 1992 lt250r that I picked last month. What I need to know from you Suzuki guys is where is the cheapest place to get parts mail order. The rear axle bearings are rough and will need replacing. Any input will help. Thank's guys[img]i/expressions/face-icon-small-confused.gif[/img]
There are tons of companys that offer cheap parts, and not a single one will have "cheap" parts across the board. Some will sell nerf bars for example at give away prices and sell bumbers higher than other companies. It's all the same everywhere you shop.
As far as the bearings go, you can get them at your local auto parts store or bearing house. You will need to get bearing #6008 [40x68x15]. You will need to get your seals from your local Suzuki dealer. KNOWSALOT |
Check rockmountain atv, you should be able to get bearings and seals for around 20 to 25 dollars.
Danno |
rocky mountain is the best deal on the axle bearings i've found too. i wish i could find that kind of deal on ball joints and tie-rod ends.
Thanks you provide excelent feedback. Your the kind of contact I may call on again.
Tie Rod Ends are just too dam* expensive!! I have replaced 2 recently and will replace the other 2 when I do my frame swap, probably in January. I can get them cheaper for my car and trucks, than I can my Quadracer. I guess If its fun they charge extra.
Danno |
