Z 400 PIPES!
#21
Z 400 PIPES!
Doughansing, you will definitely have to rejet your carb when you install your exhaust with the airbox lid removed. I believe the stock main jet is either a #125 or #130 stock. We bought our Z from Vesco's last year. We installed a Pro Flow kit with a K&N filter and a full HMF pipe. I settled on a #148 to #152 main depending on the season. We eventually installed a jet kit with the adjustable needle to dial in the midrange. After all that, we sold the Z recently and purchased a used Yoshimura Z450 with an Edelbrock carb. Man, it runs good!
#23
Z 400 PIPES!
It runs strong. The power is very broad and smooth. It doesn't hit hard like the YFZ. The power is very deceiving compared to the YFZ. I haven't dragged them side by side yet, but I think it will be close. The Z is definitely less tiring to ride, there is no comparison there. The bottom to mid is where most of the power is. I'm running an Edelbrock carb, E series pipe, with a Big Gun rev box. I would like to try some different combos to see if there's a difference. I'm very happy with the power it makes. My wife's other Z had a full HMF pipe, jet kit, Pro Flow, and Hotcams and it ran good. However, it doesn't compare to the Yoshi 450, especially in the bottom end and midrange.
I'm very happy with it. In fact I might keep it for myself, sell my YFZ, and buy the wife another Z. Haven't got that far yet. Hope this helps
#27
Z 400 PIPES!
Originally posted by: chazekxt
i have the hmf slip on but can not get the jetting wright. went to a 155 cut outs bad runns a little better with lid off but still cuts out so went to a dj jet 165 will not run with lid on runns good with it off. i ever tried going down to a 142.5 no good cuts out bad should i tri a 170? and go down from there? jetted this thing 4 time to day help?
#28
mrtidy
02-03-2016 05:00 PM
greg86hd
09-16-2015 12:32 AM
