what r best mods for Z400
i wanna know wat the best mods for thios machine is without goin to the engine, things like exhaust, air filter all things like that
That's about it. A K&N or unifilter, full exhaust, a sprocket change and some front shocks. I would also highly recommend a 40FCR. Cams also make serious power if you want to just pull the valve cover.
BIG-BORE , ported head , high compression piston, cams, stroker kit for a z-500cc, full system fom yoshimura then the high rev ignition that revs out to 11,500rpms.HOLESHOTS TOO![img]i/expressions/face-icon-small-happy.gif[/img]
OHyeah , get an EDELBROCK carburator that is slightly bigger for more top end or a smaller one for more low end[img]i/expressions/face-icon-small-wink.gif[/img]
BarelyLegal- Where did you buy your FCR carb from?? What kind of power difference did you notice, or could you compare the power difference to what the cams did?? Thanks
I got it from service honda and am still dialing it in. It should equal the HP both cams added when I'm done tuning. It's coming along pretty well but there's more in there.
