86 LT250R chain won't stay tight Help!!!!
Alright, I have a new chain and new sprocket on my quadracer, the hex head bolts are tight over the carrier, but for some reason the chain will not stay tight, and tightening it all the time is really getting annoying. Does anyone know if worn out axle bearings could be causing this?? Anyone have any other ideas??? Any help would be appreciated!!!
i had the same prob cheak it out.. loosen the four bolts on the top of the carrier.... now whent hose are loose the 2 bolts stickin out of the back of the carrier titghen them and the carrier come back slowly but keep tighten and it will tighten... then u torq those damn 4 bolts down and she aint movin... pm me if u got questions....PEACE
I had the same problem and it turns out that my carrier bearings were trashed. Changed those and hasen't loosened up for 4 weeks now.
If his bike is an 86 and had the original swing arm, then he would have the older style carrier. It has 4 alan head bolts across the back. To tighten or loosen the chain you loosen them and spin the carrier around (its oval on the outside).
Its probably just not tight enough on the outside of the carrier and letting it spin on its own. |
my bad teomaru... it totally slipped my mind that u had an 86.....i guess u wo;uld just have to loosen those 4 bolts on the back and have someone else pull back on the axle while u tighten the bolts...[img]i/expressions/face-icon-small-blush.gif[/img]
Thanx guys, I'm going to try your suggestions this weekend, I really appreciate all the help!!!!
i had a 89 and with the same problem i replaced the allen head bolts with regular bolts and it worked great but to honest with you if you have the funds get a new swing arm and up grade your suspension up front and back with todays quads with monster travel it wouldn't hurt to have more on a lt250 it's a great quad time to put some money in it and make it better
| All times are GMT -5. The time now is 02:12 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
