Vinson 4X4 ?
Does the Vinson have true four wheel drive? I mean when the going gets tough do all four wheels spin or is it the standard three whell spin? If just three wheels spin is there a diff lock system available?
Vinson 4X4 ?
The Vinson uses a torque-sensing front diff, so not true 4x4. Highlifter makes a locker kit for it if you really need it though. See highlifter.com for mud equipment.
Vinson 4X4 ?
My 01 AC 400 had the same type (I guess) limited slip diff. Generally it would do the three wheel spin. However, If I would apply a small amount of brakes then it would cause the fourth wheel to spin. I was wondering if the Suzuki worked the same way or not? Suzuki advertises that their limited slip diff send traction to all four wheels. I wanted to know how true this is.
Thanks, |
Vinson 4X4 ?
Limited slip=3 good wheels turning. I believe the brake trick will also work on the 'zuk. Suzuki's trying to sell quads, they'll tell you anything-hehe.
