Gas leaking 2005 Yamaha Kodiak 450
You may have some dirt stuck between the float needle and seat Remove the float bowl on the bott of your carburetor , push out the pin holding the float onto the carb and take out the float and inspect and clean the needle and seat. Reinstall the float , needle and bowl and see if the problem is solved
RedRancher
10-15-2020 01:45 PM
