Tail Gates / How Much Weight?
Anyone out there know how much weight a tail gate can take? I've got a 06 Nissan Tighten and need to load a 625lb 06 Vinson. I'll be using ramps to run it up into the bed but I'm concerned about the tail gate.
lol how do you think anyone else gets a quad in the back of the truck? you'll be fine
I have a Ford F350 and I take my tailgate off. I am not worried about the weight of my griz but it makes it easier to load. The angle in much less so it goes in easier.
got a arctic cat 400 its a very heavy bike and no problems here on any of my trucks
Put the ramps on your tailgate. Drive your atv up the ramps. If your tailgate collapses, it won't handle the weight. If it doesn't collapse, it will handle the weight.
toe |
Originally posted by: Crash302 I have a Ford F350 and I take my tailgate off. I am not worried about the weight of my griz but it makes it easier to load. The angle in much less so it goes in easier. |
Originally posted by: Amphib Anyone out there know how much weight a tail gate can take? I've got a 06 Nissan Tighten and need to load a 625lb 06 Vinson. I'll be using ramps to run it up into the bed but I'm concerned about the tail gate. |
Well, we got some ramps and drove it up on the Titan with no problems. Thanks for all the info. I tell ya, that Titan is no wussy. If you ever get a chance, take a close look at it and compare it to some of the others. Very solid....
Originally posted by: 400CatDriver Originally posted by: Amphib Anyone out there know how much weight a tail gate can take? I've got a 06 Nissan Tighten and need to load a 625lb 06 Vinson. I'll be using ramps to run it up into the bed but I'm concerned about the tail gate. I checked, out of curiosity, on several different pickups including Nisson and found none of the dealerships were able to supply the tailgate capacity on their products. Apparently the "try it and if it holds it's OK" attitude is the one to use. Kind of surprised me but there it is. I had a cable fail on my little Chev after it had been inspected by the local dealership and proclaimed to be OK. After the failure another dealership replaced the cables under the recall that is out. I was fortunate the other cable held as I was unloading my quad at the time and it could have been an ugly situation. |
Originally posted by: 400CatDriver Originally posted by: Crash302 I have a Ford F350 and I take my tailgate off. I am not worried about the weight of my griz but it makes it easier to load. The angle in much less so it goes in easier. |
