ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Utility ATVs (https://atvconnection.com/forums/utility-atvs/)
-   -   WHY CAN'T I PUT PADDLE TIRES ON A WOLVERINE???? (https://atvconnection.com/forums/utility-atvs/127524-why-cant-i-put-paddle-tires-wolverine.html)
GLWBEAR Dec 1, 2003 07:25 AM
Why can't I put rear Paddle tires on my Wolverine? If all the tires are say 23 inch tires why can't I put paddles on the rear wheels? Should I go with 8 or 10 paddles? any suggestions?
What should I use for the front tires? Use stock or go to something else? Has any body done this before for strickly running in the SAND?
Wouldn't this make the Wolverine better in the sand?
I'm currious if this has been done before and how did it work?[img]i/expressions/face-icon-small-smile.gif[/img]
Regards,
GLWBEAR
suzuki4ever Dec 3, 2003 04:22 PM
A freind of mine put 25 inch paddles on all 4 corners of a sp500 and ran it in deep snow. it worked really well accualy. I dont see why it wounld work on a wolvy in the sand. I would get a sidwinder or any thing with a little bit of side bite and put wide ones on the back and narow ones up front. I would also go with about 8 paddles because your wolvy dosent have the power to get the tire speed you need. All I know is it would be a hill climer.
© 2026 MH Sub I, LLC dba Internet Brands
