Need more top end for big bear!
I would not rejet. If you wanted to do the pipe I saw a good deal for two differnt kinds on ebay for the bear. Do a search on big bear.
I would say yes to the K&N filter. But I do not think it is going to give you want you desire.
I'm thinking real hard on that new stealth exhaust. I have heard good things about it.
Good luck......
Good luck......
There isnt really much you can do to the BigBear to get alot of TopEnd power out of it. As for the Gear swap that you mentioned there is alot more to it than just changing 4th and 5th. It was intended for the BigBear gears to be put in the Wolverine not the other way around. I am sure that it is possible but its going to run somewhere around a grand after all the work is said and done.
