Radiator/Coolant Question
Old Sep 14, 2006 | 08:01 PM
acpower's Avatar
Default Radiator/Coolant Question
well i went ahead and spent the $30 to buy engine ice and get it shipped here. then i find out that i shouldnt run it in the winter, good thing i didnt put it in. so today i went to the hardware store and bought their best product, which was a high-performace coolant/antifreeze. i used a 70/30 ratio mixture instead of the normal 50/50 to try and achieve their -84oF freeze point and 176oF boilover point. just wondering 1st off if that was a smart move or not. didnt say anything in the manual not to use 70/30 and the bottle said not to use less than 50/50 or more than 70/30. so i flushed my system and put my new mixture in.
i drained the reservoir also and see that no coolant is in there after i filled it. should i fill that myself manually or will the system fill it. if im supposed to fill it manually should i fill it to full cold or full hot. thanks for any help.
Old Sep 16, 2006 | 12:05 AM
Doctorturbo's Avatar
GOT BOOST!
You will be fine with your 70/30 mix. Just remember that you won't have as much freeze portection.
You should manually put your mix in the reservoir to make sure it does not freeze. Fill it to the cold line.
Old Sep 16, 2006 | 08:34 PM
v2rider's Avatar
He put 70% antifreeze and 30% water, so his freeze protection will be better than 50-50
Old Sep 17, 2006 | 01:39 PM
GOT BOOST!
Thanks v2rider, I read that wrong.
Advice still holds. The only thing is, it won't cool as well. The more antifreeze you add to the mix the less heat dispersion you will have. In other words, 100% antifreeze won't cool at good as a 50/50 mix. A 50/50 mix won't cool as good as straight water.....................etc.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
