ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Utility ATVs (https://atvconnection.com/forums/utility-atvs/)
-   -   05 sportsman 600 / cooling fan won't turn off (https://atvconnection.com/forums/utility-atvs/350950-05-sportsman-600-cooling-fan-wont-turn-off.html)
Dustin33 May 10, 2013 09:49 PM
All help will be appreciated. Fan runs all the time. Have to disconnect battery. Machine overheated on my last ride. Ever since then its ran . Any ideas??? I bought it 8 mnths ago wrecked. Ive heard that the 600 has issues with cooling. How can I fix this and antbody know how to clear the codes. Battery disconnect dont work. Thanx
old polaris tech May 11, 2013 05:00 AM
If the fan runs constantly either the thermistor wire is disconnected or the thermistor sensor has shorted out. Item#26. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Shows two different sensor according to build date. If not sure, type your VIN # here and see if it helps. VIN located on the front, etched into lower left frame behind the a-arm. Polaris ATV, RANGER Side By Side Vehicles
© 2026 MH Sub I, LLC dba Internet Brands
