ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Utility ATVs (https://atvconnection.com/forums/utility-atvs/)
-   -   Eiger gas in Crank case and airbox and now won't start (https://atvconnection.com/forums/utility-atvs/351582-eiger-gas-crank-case-airbox-now-wont-start.html)
Punchybiscuit Jun 17, 2013 01:48 PM
OK so I have a 2002 Eiger. I was riding it up my yard when it just shut off and died and would not start. When I checked the plug it was black and there was lots of fuel in the air box. I check the oil and it was full of gas also. I cleaned the carb because i assumed the float got stuck and changed to oil of course. Now I can not get my eiger to fire up. I do have good spark so it must be a carb issue. Is there adjustment I am missing or something Please help me!!!!!
hermie Jul 24, 2013 04:37 PM
check to be sure that your carb floats have not absorbed any fuel
the older plastics used were never made to tolerate ethanol or cleaners in the fuels
these 2 additives just eat away at those plastics
there are newer carb rebuild kits with new floats that tolerate the newer fuels
the fuel inlet valve is jammed open ( fill )
frootloop Nov 19, 2013 08:21 AM
Mine done the same thing I cleaned the carb and put a new pit cock in it solved the problem good luck.
© 2026 MH Sub I, LLC dba Internet Brands
