ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Utility ATVs (https://atvconnection.com/forums/utility-atvs/)
-   -   2001 kodiak won't start (https://atvconnection.com/forums/utility-atvs/374809-2001-kodiak-wont-start.html)
wwrafter Feb 3, 2018 01:41 PM
sounds like bad solenoid but replace and sounds the same, any help would be appreciated
old polaris tech Feb 3, 2018 02:43 PM
Is voltage going to the starter from the solenoid? If the solenoid just clicks,but has power to the starter,possible a starter is bad. If the starter is turning over,then could be a worn starter clutch not engaging.https://www.yamahapartshouse.com/oem...starter-clutch
wwrafter Feb 3, 2018 05:03 PM
Thank you for your reply and suggestions.
Turns out that my battery charger/emergency starter isn't working properly. I jump it from my tractor and it started immediately.
Thank you
wwrafter
old polaris tech Feb 4, 2018 12:14 AM
Check that the battery is receiving around 14 volts from the regulator at an idle or a little above.If it's charging ok,you may need to have the battery load tested if it's getting weak not holding a full charge.
wwrafter Feb 5, 2018 01:36 PM
Thanks again I will check
© 2026 MH Sub I, LLC dba Internet Brands
