Yamaha Breeze troubles? Any Ideas?
Old Jul 12, 2003 | 07:48 PM
WeAREsane's Avatar
Default Yamaha Breeze troubles? Any Ideas?
My Sons 2001 Breeze has a problem
The little quad will start fine, idle fine for about 7 - 10 minutes the stall and will not restart. If it is left to sit for about 15 mins then it will start fine again and do the same thing. The choke is only used to start intially then not used again.
I don't have alot of experience with atv repair so diagnosing something is beyond my abilities.
Does anyone out there have an Idea what might be causing this?
Thank you for any sincere replies
Old Jul 12, 2003 | 09:54 PM
TrailBlazerguy250's Avatar
is your carborater set to rich
Old Jul 12, 2003 | 11:22 PM
StockRappy's Avatar
possibly its overheating
Old Jul 13, 2003 | 02:16 AM
Blaster96's Avatar
If you jump on it, can you ride it? It sounds like it is running to hot and quites getting gas. The cylinder is probably getting to hot and not causing enough vaccum to suck in more gas. all engines are just big air pumps. Once it dies, try this. Pressurize the gas tank by blowing air into the brether hose. Then see if it start.
Old Aug 17, 2003 | 01:56 AM
ftwflh's Avatar
Check the valves
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 20, 2015 12:36 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
Jul 7, 2015 11:00 PM
