YFZ won't rev
Old Jul 20, 2003 | 08:54 PM
y2kbanshee's Avatar
Default YFZ won't rev
I've had my 450 for 11 day now and it ran perfect but yesterday i went out to take a ride and it cuts out on the top end, it almost feels like the rev limiter is kicking in but it isn't reving as high as it did before. What could be causing this all of the sudden?
Old Jul 20, 2003 | 08:58 PM
87Banshee250sx's Avatar
stuck choke? Bad gas? Not enough oil? Fouled plug? Horribly off jetting? All possibilties.
-Nick
Old Jul 20, 2003 | 09:26 PM
GYTR's Avatar
I would take it back and let them fix it.
Old Jul 20, 2003 | 10:03 PM
StockRappy's Avatar
id hook mine upside down on a chain, and let it fall, try it, itll prolly work, be safe, have fun!
Old Jul 20, 2003 | 10:13 PM
warrior007's Avatar
its probably some stupid parking brake limiter. Yamaha finds ways of putting them on most of their products. See that its adjusted properly if it has one. ..
Or when its doing it, see if you can jiggle the lever and hold on at the same time.
Old Jul 23, 2003 | 12:09 AM
RaptorRacer1's Avatar
I don't think the 450 has a parking brake limiter does it? ?
I would take it back to the dealer and have them fix it under warranty, whatever is causing it.
RR1
Old Aug 22, 2003 | 08:07 PM
amsoil123's Avatar
Did you find out what was causing it.....I've got the same problem.thanks.
Old Aug 22, 2003 | 08:25 PM
raptorblasterracer's Avatar
450 does have a parkin brake rev limiter!
RacinJason's Avatar
its a Yamaha
Old Aug 22, 2003 | 08:38 PM
maverick05's Avatar
i took my carb apart about 8 times one night cleaning and changing jets cause it was cutting out like your explaining. there were about 13 other people waiting for me so we could leave for riding trip. it turned out to be the parking brake. D@MN the parking brake, i cut the wires on mine.
