ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   warrior won't rev NEED HELP (https://atvconnection.com/forums/yamaha/112316-warrior-wont-rev-need-help.html)
87warrior87 Aug 10, 2003 03:16 PM
my warrior won't rev any higher when i get in 4-5th gear. it seems sluggesh. the plug is black. should i rejet it or what? is it too rich or too lean?
SpDdEmOn Aug 10, 2003 03:25 PM
i think that makes you rich, but if you are bone stock then it doesnt make sense for you to be rich. Try cleaning your carb, airfilter, and getting a new plug.
87warrior87 Aug 10, 2003 03:34 PM
if i took out the baffle, would that lean it out any?
shlekter Aug 10, 2003 03:59 PM
yes it could i would try taking the carb apart and cleaning it maybe there is dirt in the bowl. b4 u do all that clean the air filter and get a new plug............how does it bogg down does it like just act like it has no fuel or no air.
87warrior87 Aug 10, 2003 04:06 PM
the filter is clean. it seems like it has a rev limiter at about 5 grand. is it too rich?
87warrior87 Aug 10, 2003 04:07 PM
what color should the plug be?
87warrior87 Aug 10, 2003 04:09 PM
it does seem to choke around there. i can't even get in into 6th gear
shlekter Aug 10, 2003 04:09 PM
when it cuts out does it just completley start 2 dies or does it crack and sputter.......sounds like its not getting air
87warrior87 Aug 10, 2003 04:14 PM
it just won't build up anymore any rpm's. it just stays even. it will rev in nuetral but it takes forever to rev up in 3-5 gear
shlekter Aug 10, 2003 04:23 PM
ok if there is no sputtering or cutting out it is that your carb isnt opening all the way.........is your thumb throttle going all the way down........check the cables......
© 2026 MH Sub I, LLC dba Internet Brands
