ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Yamaha (https://atvconnection.com/forums/yamaha/)
-   -   Warrior Won't Stop...Literally (https://atvconnection.com/forums/yamaha/112439-warrior-wont-stop-literally.html)
bigairkyle Aug 11, 2003 02:37 AM
I hopped on my '04 warrior today and put in in reverse and that was the first time I noticed that the quad would "not stop." When I say this I meen that I will not be touching the throttle at all and the quad goes. I put it back in forward and the quad did the same thing...Even through all the gears. Its not like it goes fast or anything but I started thinking that since it was just like I was on the throttle it woulnd have ben good to shift or back break. So I turned the engine off that is the only way it would stop. Is there any way I can stop this. Even though I think it is pretty cool Im not sure if its good for it. Plz help fast i want to ride again.
Crotts Aug 11, 2003 03:08 AM
Is it still moving when you have the clutch pulled? If it does it sounds like you clutch cable need to be adjusted tighter.
DaBeechMan Aug 11, 2003 03:43 AM
yup. You have a clutch issue
duckdiaz Aug 11, 2003 06:37 AM
You say it’s a 04 warrior, must be brand new, why fuss take it to the dealer. Have them check it out..
NLWarrior01 Aug 11, 2003 06:43 AM
duckdiaz got it right .. take it back to the dealer. Was it like this when you bought it?
Mine will studder along in reverse when you first start it up, but after it gets warmed up that goes away.
shlekter Aug 11, 2003 12:28 PM
is the choke pullled out??
Aug 11, 2003 01:14 PM
your idle may also be high, if this happens after you let the clutch out,
Patrick
bigairkyle Aug 11, 2003 01:34 PM
Thanx for the help guys I am taking it to the dealer on Tuesday.
© 2026 MH Sub I, LLC dba Internet Brands
