Warrior- Fuel Screw Q?
when you screw in the screw does it let in more gas or less.
jw cuz when i bougt my pipe it said to turn it out 2 turns and stock it was out like 3 turns.. so j/w wouldnt u want more gas in means you opened up the air box? idk. |
Stock is 2 turns im pretty sure.
mayb idk i counted and it was like 2 3/4- 3 1/2 turns or so for stock but. if back to my 1st q?
2 turns out stock. If you turn out it leans it screw it in and it richens.
i stilll dont even c the screw like where is it.......is it inside and u haafta take the carb apart.....like what side
front he clutch sie look at the front/bottom of the carb looks like 2 tubes or w.e in the carb and on the back one on the bottom there is a little screw in it
ok so if i screw the screw in clockwise it will give my engine more fuel correct
yup.. dont screw it in to much or you will be runin rich!
i took it in all the way and i was ridin it lol it was backfiring and all heheh
