I'm so pissed
My clutch cable broke. Right where the clutch cable connects to the little round thing inside the clutch lever. God it sucks. I guess I won't be riding this weekend.
I'm so pissed
that happened to the trottle cable on my scooter
I'm so pissed
If you have plenty of adjustment down at the side case.....loosen the clutch cable clamp too give you all the length you can get. Use the extra slack too wrap around the hole in the clutch lever a couple of times and secure it with a small pair of vise grips....it will look bad, but if done right you will be riding. I have done this in a pinch.
I'm so pissed
Just go to your local dealer and get a clutch lever, any one will do as long as its long enough. I believe most ends are the same.
| All times are GMT -5. The time now is 12:32 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
