Crank Welding
Is it done before or after the crank is assembled and can it be done after its assembled? This is for my RD which is essentially a banshee crank except for the flywheel side taper.
Crank Welding
After, on the crank pin so the crank does not twist on a built or stroked motor.
Crank Welding
Isint the rod in the way though?
Crank Welding
there is a picture of a welded crank about 3/4 down this page, its welded from the side.
If you think of the crank pin as a pivot point and how the whole crank could twist on that pin you can see why welding the crank to the pin would stop it |
Crank Welding
Ok I get it now. For some reason I thought they welded it on the inside side. Guess Ill go ahead and get it done. I read somewhere that it messes up the alignment though, is that true?
Crank Welding
Done right it shouldnt mess anything up or they wouldnt do it. Have a shop look at it first to make sure its true, then have them weld it.
