Raptor coutershaft seal - O-ring too ?
Old Nov 11, 2003 | 09:22 PM
FISHER1648's Avatar
Default Raptor coutershaft seal - O-ring too ?
My coutershaft seal (#27) is leaking and I'm going to change it - should be a simple job but I noticed from the parts diagram that there is an O-ring (#26) in the mix - should I replace the O-ring too ? Could that be the cause of the leak ? I'll likely change it too (cheap) but was wondering why it's there.
Thanks, Eric
Diagram
Old Nov 11, 2003 | 09:29 PM
RacinJason's Avatar
Replace them both...mine liked to leak there...always after a dune trip...so I would just pull that spacer and wipe off the seal and it would work again...be carefull not to hurt the seal area...pull the old one with a seal puller or screw a small metal screw in to the seal grip it with pliers and pull it out
Old Nov 12, 2003 | 04:21 PM
redrocker's Avatar
The O ring is what go's bad first time
mine went I replaced everything second
time just the O ring and it fixed it I got
a few O rings just so when it go's again
I don't have down time
Old Nov 12, 2003 | 04:59 PM
warrior007's Avatar
The o-ring seals the area between the output shaft and the spacer (spacer slides over the o-ring), then the seal is between the spacer and case. So I would replace both.
exmotocrosser
Sep 13, 2019 06:12 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
Ahtatu
Sep 28, 2015 12:14 PM
black_thunder
Sep 22, 2015 07:59 PM
