aftermarket rod installation cost.
Old 02-04-2004, 12:15 PM
missinglink's Avatar
Default aftermarket rod installation cost.
Does anyone know what it cost to have an aftermarket rod installed in the raptor?
Old 02-04-2004, 12:17 PM
I was also curious if most shops can install the rod or does it take a special place to do the labor since the crank has to be balanced.
Old 02-04-2004, 12:44 PM
RaptorOwner's Avatar
I believe I was quoted 700.00
Old 02-04-2004, 01:43 PM
raptor03's Avatar
from who!!!!!!! that's way to much for that,ballancing and install should be under 400 with the rod price included in that 400..
I hope it aint no 700 dollars...
Old 02-04-2004, 02:06 PM
ok, I will check that again. Did that include your aftermarket rod?
Old 02-04-2004, 03:12 PM
raptor03's Avatar
you could get it done for 500 and some change for the complete kit and install..
Old 02-04-2004, 03:24 PM
Is that Falicon that is doing this for you?
Old 02-04-2004, 03:27 PM
660r02's Avatar
I just had a small home town shop install a Carrilo rod for me. I brought them just the block with no cylinder.
Carrilo rod=200
crank pin=30
bearing=20
gaskets=10
rebuild crank/balance=50
labor=200
total=510
Old 02-04-2004, 04:29 PM
raptor03's Avatar
trust me raptorowner they dont get no better than falicon,they guarntee a smoother idle and do a superior job...
If there is any better then let me know,and i considered the local shop(vance and hines) but i looked at the diffrence in shops and steps they take to get it right and falicon goes thru 3 or 4 steps to balance the rod and get it right the first time,there has to be some diffrence in quality when they charge 50 for the balancing and falicon charges 200..jmo
do a google search on faliconan and see the site and read up,look at how technical they get with balancing a rod and the steps they go thru,im sending mine there..
Old 02-04-2004, 05:45 PM
The Site is great!! They sound like they really got their head on their shoulders. I will have to see what I can do about mine as well.
Thanks!!
Quick Reply: aftermarket rod installation cost.
